I can't make PN7150 recognize card 2cm or more(between PN7150 and card).
馬場重人
I'm sorry my poor English. I'm Japanese.
2cm or less OK. but 2cm or more is NG.
Why I Can't?
If I need adjust settings, please teach me.
(RX_GAIN? or something else?)
Best regard.
weidong_sun
Hello 馬場 重人,
   Generally speaking, the effective range is 1cm~3cm when NFC reader reading a Tag, so I feel 2cm should be OK.
In additon, probably using LDO should be better than DC-DC converter.
TIC  weidong
Jonathan_Iglesias
Dear 馬場 重人,
hope you are doing great, I would like to know if you are using our evaluation board or if you are using your custome  board.
Jonathan
馬場重人
Mr. Jonathan Iglesias
Thank you for your reply.
I have used PN7150 SBC KIT FOR RASPBERRY PI OM5578/PN7150RPI.
I had used DC-DC converter for 3.3V power, It is not good.
But I changed form DC-DC converter to low dropout voltage regulator for 3.3V, It is good.
DC-DC converter:TI TPS54331
low dropout voltage regulator:JRC NJM2830
Is Low dropout voltage regulator better than DC-DC converter to supply PN7150?
Best regard.
weidong_sun
Hello 馬場 重人,
TIC  weidong
馬場重人
Mr. Wigros Sun
I will use that as reference from now on.
