I am using the bootloader to erase Flash with the eraseRegion command.
How big/small is the byte-count that i can use? Do i have to make shure the byteCount fits in the page-size?
I am using a "MK02FN64VLH10".
Solved! Go to Solution.
Flash is erased on sector boundaries. For MK02, the minimum erase size is 4K bytes (one sector of program flash). So the eraseRegion min eraseable bytes is 4K.
