hi I want to manufacturer a DALI, LED power, so I can use LPC1114 directly? without more software? in other word, we only need to put this IC into PCB, then it is fine? please feedback me..
The device does not have pre-loaded the program, therefore it is necessary to program the device with the desired software.
Please check the AN11174, this application note describes how to create a DALI slave device with the OM13026 LPC111x DALI slave board.
http://www.mouser.be/pdfdocs/AN11174.pdf
Soledad
