Hi, i'm new to embedded.
I'm getting hard fault error every time I try to access the 2kB Secure Session SRAM memory region in K81.
Is there any specific initialization to do ? Do I need to access it through DryIce driver ?
I am not sure what you steps to access the 2kB Secure Session SRAM. Actually please make sure there has only two ways to access it:
It worked now, the problem was with my tamper, its violation was causing hard fault error.
I appreciate the reply.
