FXTH871 ref design
FXTH871 ref design
vadimpiskun
Hi FXTH871 ref design manual shows three boards on page 5. One board is the ref design, schematics and layout are available on the website. Two other boards have no info. One of them seems to be an interface for multilink programmer. Could you please help to locate any info about those two boards? Thanks vadim
TomasVaverka
Hi Vadim,
Just copying what I already sent you through Case #00132145.
These are actually two boards, the FXTH87 module + programming interface socket (see attached). The bottom board is only the FXTH87 module itself.
Attached you can also find the schematic of the programming interface socket that gives details about pin assignment.
Hope it clarifies your question.
Tomas
