DEVKIT-MPC5748G couldn't run after reset
Question asked by ning li on Sep 4, 2017
Latest reply on Sep 7, 2017 by ning li
     Hi, I'm using DEVKIT-MPC5748G, and the hello+pll_z4_1 can run with on board open SDA with debug mode, and the led light. But if I press the  reset button, the program couldn't run from the internal flash.
     The linker file is attached.
     What's the reason?
     Thanks.
Original Attachment has been moved to: mem.ld.zip
Original Attachment has been moved to: libs.ld.zip
Original Attachment has been moved to: sections.ld.zip
