MfgTool repeat the burning process
xixiguohan
If I don't click stop button, MfgTool will repeat the burning process. Is that normal?
Why can't it stop automatically after xml commands are all executed?
Rita_Wang
And then check your hardware design refer to the reference design.
Rita_Wang
When you use the mfgtool do download the images to your board, after success download, it will stop automatically and you can see download successful done. Here you need to check the setting of mfgtool first.
xixiguohan
Hi Rita,
After download complete, the MfgTool window displayed this.
Yes, this means download successsfully, but if I don't click "Stop" button, and Exit, it will repeat to download the images after about 3 minutes.
Do you know where to set the MfgTool configurations to stop the repeat download?
Rita_Wang
Which board and BSP are you using? When download complete, I will click the stop button and exit.
Is your board designed yourself?
xixiguohan
My board is customized based on imx6sl, and BSP is customized based on Yocto. But I think this has nothing to do with my board and BSP. You can try not click the stop button, and wait for about 4 minutes. Check if it will going to happen on your board.
