Uart of MPC5744P using problem?
sunshine_hu
Hello,today i make a test,using mpc5744P's uart connect to "USB To TTL",set baudrate at the rate of 921600,when i run in sinngle debug it succes,but when i run in Full speed debuggingn it failed ,how can i avoid it?
davidtosenovjan
Hi, have you tried slower baudrate?
Actually, what you mean "single debug" and "full speed debugging". Please clarify
