MPC5748g enet_rmii_udp example
jamesx
I'm trying to run the enet_rmii_udp example project from S32DS, I updated the origin & destination MAC & IP address config in the ENET_Config.h file and then build the project and debug on the DEVKIT-MPC5748G evaluation board.
My PC and the board are connected to a same router and within same LAN. But when i run the example -
   1. I cannot find any client connection info of the mpc5748g board from router's admin page.
   2. I run an UDP server on PC with port=12345(same as the dest port on the example), it shows none udp packets received from the mpc5748g board;
   3. when I run wireshark on PC, i cannot capture any packets with ip.src == <mpc5748g IP> as well.
Any steps I'm missing to get this example running?
Can anyone helps here or point me to a document of this example?
Thanks!
caigangwu
HI, James
Has your problem been solved? I used the same project as you,and now it's work well,also i have changed some code,it's can  send and receive udp packets simultaneously now.But still have a problem,the register of receive buffer do not update when continuous get udp packets.
