how do convert a 11u14 program to 1114
jordanhalgunset
my test board is 11u14
but the project board  is 1114.
Program does not run the same on project board
jordanhalgunset
I was not able to find a driver but was to find the programs i needed.
                thank you,
                 jordan
kerryzhou
Hi Jordan,
   You are welcome!
   Driver is in folder:lpcopen_v2_00a_keil_iar_nxp_lpcxpresso_11c24\software
Wish it helps you!
Kerry
kerryzhou
Hi Jordan Halgunseth,
    You must change the head file to LPC1114, because LPC11U14 and LPC1114 have some difference. The register address also have difference.
   Please change the head file, then check the driver, you should better use the LPC1114 driver.
  About the LPC1114 driver, you can refer to lpcopen code:
LPCOpen Software for LPC11XX|NXP
Kerry
jordanhalgunset
I was not able to find the 1114 driver.
Do you know where it is located?
If you have it could you email it me?
    thank you,
     Jordan
kerryzhou
Hi Jordan,
   Can't you find the code from my last post link?
  https://www.nxp.com/downloads/en/software/lpcopen_v2_00a_keil_iar_nxp_lpcxpresso_11c24.zip
 LPCXpresso LPC11C24 board Supports LPC1111/12/13/14/15/00XL C00/C12/C14/C22/C24/D24 (Does not support 'LPC11xxLV')
Kerry
