請教各位大大  android5.1.1若發生開機程序有下列的情況 這會是發生什麼事來導致的呢?
Question asked by chen sam on Aug 22, 2017
Latest reply on Aug 27, 2017 by chen sam
Hi,All:
請教各位大大,在android5.1.1若發生開機程序有下列的情況 這會是發生什麼事來導致的呢?因為我一直停在左上角有android字樣的畫面上,卻無法進入系統內。
在麻煩大家幫忙一下了,感恩!!!
完整的訊息在附件中(.doc)以及開機停止的畫面(.jpg)。
訊息如下:  (請看紅色部份)
EXT4-fs (mmcblk3p5): mounted filesystem with ordered data mode. Opts: barrier=1
fs_mgr: __mount(source=/dev/block/mmcblk3p5,target=/system,type=ext4)=0
EXT4-fs (mmcblk3p4): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk3p4): recovery complete
EXT4-fs (mmcblk3p4): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
fs_mgr: __mount(source=/dev/block/mmcblk3p4,target=/data,type=ext4)=0
EXT4-fs (mmcblk3p6): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk3p6): recovery complete
EXT4-fs (mmcblk3p6): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
fs_mgr: __mount(source=/dev/block/mmcblk3p6,target=/cache,type=ext4)=0
EXT4-fs (mmcblk3p7): mounted filesystem with ordered data mode. Opts: (null)
fs_mgr: __mount(source=/dev/block/mmcblk3p7,target=/device,type=ext4)=0
Unable to find swap-space signature
fs_mgr: swapon failed for /dev/block/zram0
init: cannot find '/system/bin/logd', disabling 'logd'
init: cannot find '/system/bin/lmkd', disabling 'lmkd'
binder: 195:195 transaction failed 29189, size 0-0
rfkill: BT RF going to : off
random: init urandom read with 59 bits of entropy available
init: using deprecated syntax for specifying property 'ro.serialno', use ${name} instead
init: using deprecated syntax for specifying property 'ro.product.manufacturer', use ${name} instead
init: using deprecated syntax for specifying property 'ro.product.model', use ${name} instead
init: cannot find '/system/bin/debuggerd64', disabling 'debuggerd64'
init: cannot find '/system/bin/install-recovery.sh', disabling 'flash_recovery'
fs_mgr: Cannot open file /fstab.
android_usb: already disabled
mtp_bind_config
root@android:/ # init: untracked pid 247 killed by signal 9
healthd: BatteryTemperaturePath not found
healthd: BatteryTechnologyPath not found
init: untracked pid 298 exited with status 0
random: nonblocking pool is initialized
init: untracked pid 324 killed by signal 9
init: untracked pid 354 killed by signal 9
init: untracked pid 382 killed by signal 9
init: untracked pid 408 killed by signal 9
init: untracked pid 435 exited with status 2
init: untracked pid 468 killed by signal 9
init: untracked pid 494 exited with status 0
init: untracked pid 526 killed by signal 9
init: untracked pid 549 killed by signal 9
init: untracked pid 576 killed by signal 9
init: untracked pid 605 killed by signal 9
init: untracked pid 631 killed by signal 9
init: untracked pid 657 killed by signal 9
init: untracked pid 683 killed by signal 9
init: untracked pid 706 killed by signal 9
init: untracked pid 730 killed by signal 9
init: untracked pid 789 killed by signal 9
init: untracked pid 815 killed by signal 9
binder: undelivered transaction 154
init: untracked pid 842 exited with status 2
init: untracked pid 871 killed by signal 9
init: untracked pid 897 killed by signal 9
init: untracked pid 921 killed by signal 9
init: untracked pid 944 killed by signal 9
init: untracked pid 971 killed by signal 9
init: untracked pid 1001 killed by signal 9
init: untracked pid 1026 killed by signal 9
init: untracked pid 1054 killed by signal 9
