imx6Q  Temperature:   0 C, calibration data 0x5604c57d
Question asked by jianfei zheng on Aug 22, 2017
      Hello everyone,have you ever encountered a problem that imx6q print "Temperature:   0 C, calibration data 0x5604c57d".why the Temperature is 0 C? And what is worse,the imx6q can not launch GPU normally,it will print a lot of error log such as "DMA appears to be stuck at this address " .And then,a  moment later,the board will reboot and repeat the err. Does someone have any suggestion about the reason and solution?
      Thanks very much!
Original Attachment has been moved to: Serial-COM4_20170725-140707.dat.zip
