I would need to get some info about the MPC5604B (SPC5604B), which i could not find in the datasheet yet (http://www.nxp.com/docs/en/data-sheet/MPC5604BC.pdf )
Could you give some input on this 2 points?:
Requirement Verification - NON-VOLATILE MEMORY (NVM) RELIABILITY:
* Specification of annual failure rate, confidence level and temperature profile.
* Specification of minimum write/erase cycles and data retention.
Thank you and Greetings
Renato
