Facing issue to bring up Android N on IMX6Q-SDB Board
Question asked by Nirav Shah on Aug 18, 2017
I am trying to bring up Android N on IMX6Q-SDB board.
I am using prebuilt image shared on below link.
Android N7.1.1_1.0.0 Release Announcement
I  tried to load images using SD card using fsl-sdcard-partition.sh script from source code.
I followed below steps to flash sd card
$ cd ~/myandroid/
$ sudo chmod +x ./device/fsl/common/tools/fsl-sdcard-partition.sh $
sudo ./device/fsl/common/tools/fsl-sdcard-partition.sh -f imx6q /dev/sdX
Then I changed boot switch setting to (SW6) 01000010 (from 1-8 bit) to boot from SD3 slot.
I used below boot arg to boot from SD3 slot and with HDMI display.
setenv fastboot_dev mmc1
setenv bootcmd boota mmc1
setenv ethaddr 00:04:9f:00:ea:d3
setenv fec_addr 00:04:9f:00:ea:d3
setenv bootargs console=ttymxc0,115200 androidboot.console=ttymxc0 consoleblank=0 vmalloc=128M init=/init video=mxcfb0:dev=hdmi,1920x1080M@60,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off androidboot.hardware=freescale cma=448M androidboot.selinux=permissive androidboot.dm_verity=disabled
saveenv
But I am only seeing "Android" Written on HDMI screen and not able to get Android command prompt on serial.
Can you please suggest next troubleshooting steps to boot android on IMX6 board or I am doing anything wrong?
Please find attached log file.
Original Attachment has been moved to: flashing_sd_card_logs.txt.zip
Original Attachment has been moved to: prebuilt_serial_logs.txt.zip
