MQX 4.2 on iMX7
MQX 4.2 on iMX7
dry
Senior Contributor I
Is there a configuration available to run MQX 4.2 on iMX7?  ( Only interested for the M4 core really. )
Maybe there is BSP available for MQX 4.2  for IMX7 Sabre board?
danielchen
Hi D. RY
unfortunately,  there isn't a configuration available to run on MQX 4.2 on i.MX7.
i.MX7 Sabre Board is supported in MQX v5, please check the below link.
MQX™ v5 Software Solutions|NXP
If you need to port it by yourself, you can refer to the below porting guide.
Freescale_MQX_4_2\doc\mqx\MQX_BSP_Porting_Guide.pdf
Have a nice day,
Note: If this post answers your question, please click the Correct Answer button or helpful. Thank you!
dry
Hello Daniel
Is MQX v5 still uses MCC for inter core comm?  Does NXP have  rpmsg available for MQX?
There seems NXP made an rpmsg port for FreeRTOS?
danielchen
Let me check this with the develop team and will get it back to you when I have results
danielchen
Hi D. RY
Please refer to the following link for the inter core communication
What does MQX5 use for inter core communication?
"MQXv5 has MCC available and RPMsg is being added as an alternate."
