I'm using S32K144 and S32 DESIGN STUDIO,
Can I use the Segger J-LINK PRO with S32 DESIGN STUDIO?
I don't see this option under debugger window, all I see is the multi link tools.
Hello!
I am new to the NXP S32 Design Studio
and I have succeeded on using the PEMicro Debugger in it.
However, when I try to connect the J-Link Debugger for my S32K148 EVB,
I would encounter the following error and have no idea on how to resolve it please.
Therefore, I would like to ask if any idea please.
Would it be because I am still using the same Project file for PEMicro debugger before please?!
Thanks & Regards,
Robert
S32 Design Studio integrates Segger GDB server:
About J-Link GDB Server | SEGGER - The Embedded Experts
You have to create a new project and select "Segger J-link GDB server"
or add and a new debug configuration into "GDB Segger J-Link Debugging" section into your existing project.
Hope it helps.
Stan
