MK10FX512VLQ12 is not supported neither in MCUXpresso-Config-Tools nor in SDK-builder.
If I take the nearest component from the list MK10DX256xxx10, I have neither FTM3-timer, nor CMP3-comparator for example...
What to do? (beside manual configuration)
best regards
Peter
Hi Peter,
based on this document: https://community.nxp.com/docs/DOC-333073 this device is not planned to be supported by SDK or in MCUXpresso-Config-Tools. I'd recommend to select supported derivative from the spreadsheet or directly in the MCUXpresso-Config-Tools.
Marek
