HTTP Request on lpc1768
navidansari
hi
I have lpc1768 and  DP83848CVV  as Ethernet PHY
I want to send HTTP request to lpc1768
till now I open port and send and get TCP socket and I have a web page that showing simple text
what should I do to be able to get and process HTTP request ?just point me in a right direction or right documentation
the example that exists is old and I can't use it
Carlos_Mendoza
Hi Navid,
Which old example are you referring to? I would recommend you to use as reference the latest available LPCOpen 2.10 package, in specific the webserver example:
LPCOpen Software for LPC17XX|NXP
If you are using MCUXpresso the LPCOpen package is already included in the installation:
Hope it helps!
Carlos Mendoza
Technical Support Engineer
navidansari
im using keil
Carlos_Mendoza
Hi Navid,
Then you should download this package:
Hope it helps!
Carlos Mendoza
