the offical reference design use the RGMII interface to ar8031 to realize 10/100/1000M,can i directly replace the ar8031 with DP83848 still using the RGMII interface?or should i use the NVCC_ENET portion interface with DP83848? Can somebody smart reply to me quickly?I'M so eager。
Hi zhang
unfortunately DP83848 has not RGMII interface according to below link, so can not be replaced directly
One can use RMII interface, please check i.MX6 System Development User’s Guide
http://www.nxp.com/docs/en/user-guide/IMX6DQ6SDLHDG.pdf
