I'm using MCUExpresso IDE with SDK2.x. I've imported the SDK example of freertos I2c. Everything works fine with compiling and debugging, but it always fails with a kStatus_I2C_Addr_Nak. Is there something I need to do with teh board to make this example work?
Solved! Go to Solution.
OK, RTFM. Problem solved. Read the doc/readme.txt file and the proper connections are shown.
