EEPROM ECC Error injection in MPC5746R
Question asked by Renjith R on Aug 14, 2017
Latest reply on Aug 22, 2017 by David Tosenovjan
I need to test EEPROM for single bit/multi bit error using ECC in MPC5746R. I refereed the following post:
Example MPC5777C-1b+2b_FLASH_ECC_error_injection GHS614
Using this i was able to generate flash fault. Similarly I want to test EEPROM for single bit/multi bit error.
I tried modifying the address range of flash block to EEPROM block in the above sample code(since it is emulated flash eeprom). But I am not able to inject any fault.So please suggest any methods available.
RR
