You can use LPCOpen software for LPC11xx. LPCOpen Software for LPC11XX|NXP
LPCOpen contains an I2C example that you can use as reference. This example shows how to use I2C as master or slave and communicate between Master and Slave with polling/interrupt mode. (Interrupt mode is default).
I hope this helps,
Soledad
Hi Soledad,
Thank you for your direction.
I will try use it.
py ot
