driver_examples of SDK_2.2_LPC54608J512,sdcard-fatfs has erased other files existed in SD
zhixiangzeng
When I was doing this demo, I created the file in SD card,  both DIR1 and DIR2 succeeded, but wiped out all the files in my SD card. What's the reason for this? Is there a way not to erase?
kerryzhou
Hello zhixiang,
    Just do this modification:
1. open ffconf.h
   Line 50, change _USE_MKFS to 0.
Disable f_mkfs function
2. New test result
  This is my test result in the SD card.
After point 1 modification, build and download it to the board again.
You can find the folder test and test.txt still exist.
You can try it on your side.
Kerry
kerryzhou
Hello zhixiang zeng,
    Do you use the official KSDK sd sample code directly on LPC54608 board?
   Could you give me the details steps which can reproduce your problem? Then I can check and test it on my side.
Kerry
zhixiangzeng
Hi,there are  1 file and 1 folder  existed my SD card .When after I run the examples "SDK_2.2_LPC54608J512\boards\lpcxpresso54608\driver_examples\sdcard_fatfs",the  both DIR1 and DIR2 succeeded123.png
but  the file test and folder test have been erased.There are only the DIR_1 created by the fatfs.
kerryzhou
Hi Zhixiang,
   Just as I have told you, f_mkfs function will do the disc format, more details please check this link:
FatFs - f_mkfs
Wish it helps you!
Kerry
zhixiangzeng
How to avoid deleting other  files in my SD card ? Do you have any ideas or suggestions?
kerryzhou
Hello zhixiang,
1. open ffconf.h
2. New test result
Kerry
zhixiangzeng
Hi,Kerry!
       I have solved the problem last night, and the modifications I made were the same as you mentioned. Anyway, thank you very much for your support.
kerryzhou
Hello Zhixiang,
   You are welcome!
   If your problem is solved, please mark the correct answer to close this case, thank you and have a nice day!
Kerry
kerryzhou
Hi Zhixiang,
   I already reproduce your problem, and I am working on it, it needs time to process it.
  f_mkfs function will delete all the file in the SD card. I am still checking it.
   Any updated information will let you know, please wait patiently now.
   Thanks a lot for your understanding.
Kerry
