Bootloader example code for MQX 4.2 ?
王志升
I am porting my system from MQX 4.0 to MQX 4.2  but I can't find example code of "Bootloader" in version 4.2.
I read the release note of MQX 4.2. It shows that Bootloader is avalable , but there is no example code.(there are only
bootloader_vybrid and bootloader_vybrid_qspixip.No bootloader!!)
I installed MQX4.1 before and I can see all the three item, but my system need MQX4.2 to support K64.
Or it's just no example, MQX 4.2. still support the old Bootloader of 4.0 & 4.1.
Thanks in advance.
Justin
danielchen
Hi Justin:
Unfortunately there isn't an example like what you need. The bootloader in MQX 4.1 is for Coldfire not for Kinetis devices.
However NXP/Freescale provides some application notes about Kinetis K product bootloader.  You can use this for reference.
AN4370 USB DFU Bootloader for MCUs
http://cache.nxp.com/docs/en/application-note/AN4370.pdf?fsrch=1&sr=2&pageNum=1
AN4368 USB MSD storage device host bootloader
http://cache.nxp.com/docs/en/application-note/AN4368.pdf?fsrch=1&sr=1&pageNum=1
AN4379 Freescale USB Mass Storage Device bootloader
http://cache.nxp.com/docs/en/application-note/AN4379.pdf?fsrch=1&sr=1&pageNum=1
AN4367 Ethernet Bootloader for MCU
http://cache.nxp.com/docs/en/application-note/AN4367.pdf?fsrch=1&sr=1&pageNum=1
I hope it helps
Note: Please click helpful or correct answer if it helps, thanks
王志升
Who has the experience of "TFTP Bootloader" on MQX4.2?
Please give me help.
      Justin
danielchen
Hi Justin:
I hope it helps
jjt
The app note might help, but the link you provide returns "Not Found".
jjt
Link for AN4367 no longer links to anything.
Search for AN4367 is also a dead end.
Is there any support for a K60 ethernet based boot loader?
