About the register value of i.MX283 when using NAND flash memory.
貴博石川
Hi NXP,
We use one NAND flash memory.
Please teach us the recommended register value of the GPMI.
Please refer to the following register item.
The NAND flash memory is MT29F4G08ABADAWP-ITD(Micron).
After setting register value, we will measure and inspect control signals.
If necessary, we adjust the register value.
Processor : MCIMX283DVM4B
NAND Flash Memory : MT29F4G08ABADAWP-ITD(Micron)
Register of GPMI:
<address> <register name>
8000_C000 GPMI Control Register 0 (HW_GPMI_CTRL0)
8000_C010 GPMI Compare Register (HW_GPMI_COMPARE)
8000_C020 GPMI Integrated ECC Control Register (HW_GPMI_ECCCTRL)
8000_C030 GPMI Integrated ECC Transfer Count Register (HW_GPMI_ECCCOUNT)
8000_C040 GPMI Payload Address Register (HW_GPMI_PAYLOAD)
8000_C050 GPMI Auxiliary Address Register (HW_GPMI_AUXILIARY)
8000_C060 GPMI Control Register 1 (HW_GPMI_CTRL1)
8000_C070 GPMI Timing Register 0 (HW_GPMI_TIMING0)
8000_C080 GPMI Timing Register 1 (HW_GPMI_TIMING1)
8000_C0A0 GPMI DMA Data Transfer Register (HW_GPMI_DATA)
8000_C0B0 GPMI Status Register (HW_GPMI_STAT)
8000_C0C0 GPMI Debug Information Register (HW_GPMI_DEBUG)
8000_C0D0 GPMI Version Register (HW_GPMI_VERSION)
Hi 貴博 石川
simple way to check registers with baremetal obds tests (folder drivers/nand):
Lab and Test Software (1)
On-Board Diagnostic Suit for the i.MX28
http://www.nxp.com/products/developer-resources/software-development-tools/i.mx-software-and-tools/i...
