Does fsl recipes supports initramfs with core-image-minimal-initramfs ?
Thank you,
Ran
Hi Igor,
I don't see core-image-minimal-initramfs listed in table 1 (page 8 in the pdf you've attached).
So, I am not sure it is supported by freescale/nxp. Is it ?
Thank you,
Ran
Hi Ran
you are right, table 1 does not mentions it.
Mfg tools recipy produces fsl-image-mfgtool-initramfs.. (can be found in
/firmware folder) which is also very small.
Hi Ran
one can look at mfg tool recipies described in attached Yocto Guide
sect.6.2 Manufacturing Tool, MFGTool
