Kinetis K64F SDK_3.1 + KSDK_1.3.0 USB recommendations
neilporven
Senior Contributor I
Hi everyone,
I would like to know if someone has successfully used the USB module that comes with the K64F and developed
an application?
What issues, if any, where experienced after it was completed? Is it stable?
I am using SDK_3.1 and KSDK_1.3.0 to develop my USB (HOST) driver application.  This will be a bare metal application, no PE(Processor Expert).  I am planning to use the Fatfs
to do file reads/writes/create etc....
If someone can comment on the above, I would appreciate it.
Thank you,
Neil
Tags (3)
