GPIO set value and get value
Question asked by cily mo on Aug 3, 2017
Latest reply on Aug 4, 2017 by Rita Wang
Hi:
     I'm confused for the gpio control. Here is my step:
       1:    int pin_num = of_get_named_gpio(np, "345-en,fsl", 0);   //GPIO2 IO03  pin_num = 35;
       2:    gpio_direction_output(pin_num, 1);   //Voltage high
      3:    gpiod_get_value(gpio_to_desc(pin_num));   //get "0"
       4:    gpiod_set_value(gpio_to_desc(pin_num),0);   //voltage low
       5:    gpiod_get_value(gpio_to_desc(pin_num));  //get "0"
       6:   gpiod_set_value(gpio_to_desc(pin_num),1);  //voltage high
      7:   gpiod_get_value(gpio_to_desc(pin_num)); //get "0"
       Every time I get the gpio value is "0",  but the pin voltage is the same(high/low) what I set.  how can i get the GPIO value after i set.
