I configure the DSPI block ,and Connect pins (C4 to A5 ). Connect pins (C7 to A7 ).Connect pins (C6 to A8).Connect pins (C5 to A6),i wanna use the can block to send out the data that DSPI received ,But there is not anything! and i used the scope to view the pin of the DSPI_out,and has not the data,too!
The attachment is my Model. Can you help me slove it?
Can you send me a exzample about The DSPI model? the crystal oscillator of my board is 8MHZ .
and i test my CAN block that is right!
Original Attachment has been moved to: DSPI_can_simple_bloc.mdl.zip
Hi Eden Li,
I'm out of office until August 21st without access to Matlab/Toolboxes/Boards.
As far as i know there is an example about DPI in the toolbox itself. Have you tried that one ?
I'll ask one of my colleagues to have a look over your model.
