MPC5674F boot up time
youngseolee
I am currently using the MPC5674F, and I have a question about a boot up time time.
I am wondering about the MPC5674F boot up time, which is the time it takes for the BAM reset vector or uset_init() to run after the reset signal is asserted to the MPC5674F.
Where can I find more details on this?
I will wait for your reply.
petervlna
I have check the documentation and BAM execution time is not defined.
So you have to measure it yourself.
Measure time from reset release to pin toggle right after BAM finishes.
This will give you good overview on how long BAM takes.
Peter
