How are unconnected pins to be handled? Should both the input and output buffers be disabled, or should they be set as inputs? I didn't see it mentioned in the datasheet
Hi Allison,
Thanks Petr. Just to confirm, this is for completely unused pins. Would this be the same for test points, setting all to GPIO function as well as disabling both buffers?
