Hello, i'm a beginner in KDS and MQX and I need implement RTOS MQX in a Freedom k64F. I have this problem when I try to compile my project:
arm-none-eabi-gcc: error: /opt/Freescale/KDS_3.0.0/toolchain/lib/gcc/arm-none-eabi/4.8.0/m4/fp/v4-sp-d16/libgcc.a: No such file or directory
arm-none-eabi-gcc: error: /opt/Freescale/KDS_3.0.0/toolchain/arm-none-eabi/lib/m4/fp/v4-sp-d16/libc.a: No such file or directory
arm-none-eabi-gcc: error: /opt/Freescale/KDS_3.0.0/toolchain/arm-none-eabi/lib/m4/fp/v4-sp-d16/libsupc++.a: No such file or directory
arm-none-eabi-gcc: error: /opt/Freescale/KDS_3.0.0/toolchain/arm-none-eabi/lib/m4/fp/v4-sp-d16/libm.a: No such file or directory
Notes:
I use Ubuntu 16.04 LTS.
KDS ver 3.0.0 but previously I used 3.2.0 with the same results.
I don't find a lot information about KIDS and MQX so I used youtube this tutorial:
3 Primer Proyecto Con MQX - YouTube
thanks and if you know a best tutorial please let me know.
Hi luis:
From your message, it seems the tool chain isn't installed correctly. you can check the relative folder to see whether the complained libraries exist. I would suggest you reinstall MQX RTOS 4.2.0 Linux Base and KDS 3.2 again.
Please also check below link
https://community.nxp.com/message/534518
