I am trying to understand how to load image file to kw40z OTAP. I tried to OTAP using nxp tool 12. In the hex file transferred, I read a header sector+unknow sector+.bin image. What is the sector after the header? Is it sector bitmap?
Vincent
Hello ,
I believe that you will find the answer to your question by checking the Bluetooth® Low Energy Application Developer’s Guide (BLEADG.pdf) on the chapter 11 Over the Air Programming (OTAP) where you can find more information about the commands, bootloader, format, etc.
Estephania
