*.rbf file flash
*.rbf file flash
jiangfeng
Hi,Dear Surpport:
I download the s12zvm.rbf  file into the S12ZVMx12EVB when I used the Motor Control toolbox  .
However I can't flash any other program into the board via BDM after finishing the s12zvm.rbf.
So I want to erase the bootloader while it 's been protected like the last picture.
Could you help me to solve this? Thanks very much.
dumitru-daniel_
Hi jiangfeng‌,
Have you tried to check the "Unprotect flash memory before erase" option ? Is it the same error ?
jiangfeng
Hi, Daniel
First Thanks for your answers,
I just tried your methods, but it didn't work well ,like the following picture.
dumitru-daniel_
Hi jiangfeng‌,
What about from Matlab ? Does it still work to download an application into the flash memory this way ?
I want to check if this is a system issue or is just an issue with flash operations from CW IDE.
