Is LPUART just low powered version of UART?
Hello John Man,
If you check the reference manual about the LPUART and UART, you will find the difference.
LPUART is the low power UART, it can works in the low power mode, I post some information for your reference:
1.LPUART
2. Normally UART
Wish it helps you!
Kerry
