I am using LPC11c24 Xpresso board, My query is how to write a array of data(Max 8bytes) into Flash memory and read the same when required after Power reset .Is there any API or any sample code available. Can anyone help me in this regards
Hi sridharan j ,
TIC
Hi JeremZhou,
I am able to write and read page wise with block number. I used API.c and API.h files to achieve this.
Thank you for the support
Sridharan J
