ICODE DNA Mutual Authentication MAM2 response UNKNOWN error
gshankarappa
I am using Mutual Authentication method to authenticate the ICODE DNA RFID tag, I get good response for the MAM1 command, I decrypt the answer part and it matches to what I send, then I collect the un-encrypted message part and append to form the response, I get 0x0F error code back, which is an Unknown error. Can anyone describe what scenarios can lead to 0x0F error and also describe in detail the command parameters for the MAM2 message. I didn’t exactly understand what is IChallenge_MAM here. I have tested my firmware to make sure it is working fine by replicating the command contents for a given response as described in AN11808.
gshankarappa
Nope. no progress at all. Never heard anything back from NXP too.
Kan_Li
Hi Gireesh,
I am sorry, but I didn't find AN11808 from nxp.com nor the docstore, is it a NXP doc? Please kindly help to clarify.
Kan
gshankarappa
It is a NXP doc, I got it from docstore .
slou26
Hello, did you find something ?
