I am working on MCUXpresso with LPC1830 project, with some project modification (ex: re-name project name...)
There is an issue now,
I only modify one file, but my project is re-build every time (I don't clean it before build).
What setting can I fix this issue.
Ken
Hi Ken,
after renaming a project, you have to update the refresh policy too, see Eclipse Project ‘Refresh Policy’: Broken Incremental Build with External Make? | MCU on Eclipse
I hope this helps,
Erich
Hi Erich
Thank you,
with the refresh policy setting,
My problem is solved.
Ken
