Hi Guys,
I use the S32 compiler to generate the MAP file shown as the attchment named A.map,
and the other compiler is named B.map,
how can i make the fromat of the A to the format that B.map?
Original Attachment has been moved to: B.map.zip
Original Attachment has been moved to: A.map.zip
I'm afraid that you can't simply convert gcc/ld map file output format to format of Texas Instrument map file.
If you need the "B" format as an input for parser - you have to modify your parser to be able handle gcc/ld map file format.
Jiri
never-displayed
