An error has ocurred, see the log file C:\Freescale\KDS_v3\configuration
gerardoramos
!SESSION 2017-07-14 16:03:52.595 -----------------------------------------------
eclipse.buildId=3.2.0.201603041649
java.version=1.7.0_76
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=es_MX
Framework arguments: -product com.somniumtech.branding.kds.ide
Command-line arguments: -os win32 -ws win32 -arch x86 -product com.somniumtech.branding.kds.ide
!ENTRY org.eclipse.jface 4 0 2017-07-14 16:03:54.774
!MESSAGE FrameworkEvent ERROR
!STACK 0
java.util.zip.ZipException: Exception in opening zip file: C:\Freescale\KDS_v3\eclipse\plugins\org.eclipse.jface_3.10.2.v20141021-1035.jar
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:301)
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.basicOpen(ZipBundleFile.java:85)
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.getZipFile(ZipBundleFile.java:98)
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.checkedOpen(ZipBundleFile.java:65)
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.getEntry(ZipBundleFile.java:232)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:562)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:540)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:527)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:391)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.lang.ClassLoader.loadClass(Unknown Source)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.osgi.internal.framework.BundleContextImpl.loadBundleActivator(BundleContextImpl.java:755)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:706)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319)
at org.eclipse.osgi.container.Module.doStart(Module.java:571)
at org.eclipse.osgi.container.Module.start(Module.java:439)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:191)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Caused by: java.util.zip.ZipException: zip file is empty
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(Unknown Source)
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:288)
... 56 more
!ENTRY org.eclipse.osgi 4 0 2017-07-14 16:03:54.778
!MESSAGE An error occurred while automatically activating bundle org.eclipse.ui.workbench (496).
!STACK 0
org.osgi.framework.BundleException: Error starting module.
at org.eclipse.osgi.container.Module.doStart(Module.java:580)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/jface/dialogs/IDialogSettings
... 32 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.jface.dialogs.IDialogSettings cannot be found by org.eclipse.ui.workbench_3.106.2.v20150204-1030
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:432)
... 41 more
Root exception:
... 41 more
!ENTRY org.eclipse.osgi 4 0 2017-07-14 16:03:54.823
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.ui.ide.application" was unable to instantiate class "org.eclipse.ui.internal.ide.application.IDEApplication".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:188)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/ui/application/WorkbenchAdvisor
... 15 more
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.ui.workbench (496).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:116)
... 20 more
Caused by: org.osgi.framework.BundleException: Error starting module.
... 29 more
... 32 more
... 41 more
no puedo abrir el KINETIS por causa de este error ¿alguien sabe como reparalo?
marek-trmac
Hi Gerardo,
I'd recommend to re-install KDS.
Marek
Marek
gerardoramos
Thanks, I have to re-install KDS and solved the problem
Hello Gerardo,
I am interested to know how get the error, when open KDS ? Or when debug project ? Or something else ?
And also could you please take a screenshot about the error message , thanks.
Alice
