Problem About Debugging on EVB of MPC5744P
hbw
Recently,I am learning MPC5744P.However,I can not debug it by S32 IDE normally.The problem is as follows:
     After I Click "Debug" button,it will appear the Dialog as below:
Then,it will appear:
Finally,the debug is aborted.
Hoping can be solved,thanks!
Best Wishes!
hbw
     Excited! The problem has been solved.I change my IDE into S32  for Power IDE 1.2 version.Then the problem is solved.
I think the problem may be duo to the compatibility between IDE and Debug emulator.
     That's all.
hbw
There are pictures:
