I am very much new to IMX6SX programming and would like to know about IOMUX. I believe that there would be a detailed document about IO MUX for beginners. Can you please share the document details?
Thnaks
You can refer to the pin mux configuration, using section 4.1.1 (Muxing Options)
of the IMX6SXRM.pdf. And the i.MX_6_Linux_Reference_Manual.pdf the section 3.5 IOMUX
Rita
I have already gone through this. What I want is the detailed description of IOMUXC. Like the architecture, how mux regs used, how config regs used, how the behavior changes when we change these registers etc. Ideally a document that explain IOMUX in a detailed manner.
