I am working on a board which is having two LVDS displays and two Audio codecs. I am porting MORTY SDK on it. Gstreamer1.0 package is available in MORTY. I am able to play audio on both the codecs but I am unable to play video on both the displays. Also I am unable to play audio and video simultaneously. Can anyone tell me gst-launch-1.0 pipeline description so that I can sync audio and video at same time?
Thanks.
Akash Chandra
Hi Akash
please refer to attached Linux Guide sect.7.3.1.3 Audio/Video file playback,
use nxp bsps described on
http://www.nxp.com/products/software-and-tools/software-development-tools/i.mx-software-and-tools/i....
Hi Igor,
Thanks for your response. According to Linux Guide section7.3.1.3 we should know audio-video decoder and sink plugins. I am unable to find those plugins. I used gst-inspect-1.0 command to find the plugins and tried the following command:
gst-launch-1.0 filesrc location=/media/Coldplay.mp4 typefind=true ! imxvpudec ! imxipuvideosink &
But it showed the following errors:
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
ERROR: from element /GstPipeline:pipeline0/GstImxVpuDecoder:imxvpudecoder0: VPU decoder was not created
Additional debug info:
../src/vpu/decoder.c(466): gst_imx_vpu_decoder_handle_frame (): /GstPipeline:pipeline0/GstImxVpuDecoder:imxvpudecoder0
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
Freeing pipeline ...
Do you know how to find the required plugins?
Thanks.
Akash Chandra
Hi Akash
what processor and board used in the case ?
Hi Igor ,
I am using IMX6QUAD processor and im6qsabersd board. Is there any issue in plugins?
Thanks.
Akash Chandra
Hi Akash
please try Demo Images
