kernel Bug at qman\bman _config.c
Question asked by mohsen haghighat on Jul 11, 2017
Latest reply on Jul 22, 2017 by mohsen haghighat
We design a T1022 custom board. In this design we load U-boot on NOR-Flash and now we try to boot a OS on it.
We make a kernel (UIMAGE dtb and rootfs) with SDK, we use its default config in Menuconfig. Then we boot these files on my board and see this error:
" kernel BUG at /home/me/SDK/QorIQ-SDK-V2.0-20160527-yocto/build_t1042d4rdb/tmp/work-shared/t1042d4rdb/kernel-source/drivers/staging/fsl_qbman/qman_config.c
Oops: Exception in kernel mode, sig: 5 [#1]"
I attach the console logs.
I understand that this error happend because of qman and bman, So in menuconifg I deselect it. I do not use USB on my board so I deselect the USB Support. Then I load the file on my board and OS boot seccesfully. I attach my.config file and linux dmesg logs.
bootm 1000000 3000000 1fc0000
What can i do for qman bman error?
thanks,
Original Attachment has been moved to: config.zip
Original Attachment has been moved to: logs_qman_error.txt.zip
