MPC5748G Io port drive current
yankuang1
I would like to know how much MPC5748G IO port drive current is,I checked the 5748g data sheet as shown below:
Do I have to configure the ipp_sre bit to get a different drive current value?But I can not find the ipp_sre bit in the MPC5748G user manual.
davidtosenovjan
It'll be SRC field in MSCR register.
Datasheet apparently uses some term from internal documents. I will report it as documentation error. Thanks for highlighting of the issue.
