Hello everyone, about EPID:
When my device was initialized,
I used the hZPS_eAplAibSetApsUseExtendedPanId (0x12345678) function, and then involk the DBG_vPrintf (TRACE_SWITCH_NODE, "EPID: 0x% 016llx \ n", ZPS_u64NwkNibGetEpid (ZPS_pvAplZdoGetNwkHandle ())), why the printed EPID is still 0? I do not understand.
Hi Liu Xiang,
If the value is zero on the Coordinator, the device will use its own IEEE/MAC address as the EPID.
A zero value on a Router/End Device means that the device will not look for a particular EPID when joining a network.
Mario
