CMSIS Driver Library Examples Don't Work
williambonsmann
I am currently trying to work with the LPC43xx CMSIS Peripheral Driver Library
I have already loaded uvision5 blinky example onto the board and modified the code to work with a button press.
Now however, I am trying to get the UART peripheral working and decided to use the CMSIS peripheral driver library for this application. I have approached this problem by first trying to get the CMSIS GPIO Blinky example working however when I try and load it onto the chip it freezes the program that was previously running and doesn't load. I have edited the main code to make it relevant to the MCB4300 evaluation board I am using.
Does anyone know a fix for this problem?
Labels (3)
Tags (3)
soledad
Please check the below links:
CMSIS support in LPCXpresso IDE
https://community.nxp.com/thread/388987
Remember:
"The use of LPCOpen is now recommend for most LPC MCUs, rather than the 'old-style' CMSIS-CORE library projects and examples. For more details please see the LPCXpresso IDE User Manual, and visit the LPCOpen webpages."
Soledad
