PTP CLOCK AND INTERRUPTS USAGE FOR FEC IN DTSI
himabindu
Hi Team,
                   Currently I am working on IMX6 Sololite Linux Kernel Version 3.10.17. For Ethernet to successfully work, along with ipg clock i should provide the ptp clock in the dts file.Kindly help me in the usage of Interrupts-extended option and ptp clock initialization for fec in imx6sl.dtsi file.Also File Transfer is getting stalled.
Iam getting the below Error with ptp in fec :
[ 1.263428] ERROR: could not get clock /soc/aips-bus@02100000/ethernet@02188000:ptp(2)
Thanks & Regards,
C.Himabindu.
himabindu
Hi Team,
                Kindly help me in resolving the stalled issue and speed issue while transferring the Files using Ethernet. I am using clk_ipg as the Reference clock and clock is defined with a period of 26 MHz speed.
time scp uImage 192.168.1.13:/root/
root@192.168.2.13's password:
uImage 63% 3488KB 0.0KB/s - stalled
Thanks & Regards,
C.Himabindu.
Hi HIMA
IMX6 Sololite does not support ptp, please check that correct dts file was used:
imx6sl-evk.dts
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/tree/arch/arm/boot/dts/imx6sl-evk.dts?h=...
himabindu
Hi Team,
Thanks & Regards,
C.Himabindu.
