4-5 second video lag while live streaming data through a wifi borescope in sabresd
himanshugusain
I have few sabresd boards from freescale which runs on Android 4.4 & 5.0.2
Recently I integrated the Wi-Fi Streaming application in all the tools
& found their is a lag of 4-5 in the data received in the Tool when connected to a borescope.
What could be possible issue , Is it something to do with the VPU in imx6 side
Himanshu
Labels (4)
Hi Himanshu
had you tried to measure delays without wi-fi,
for vpu one can try to enable low-latency plugin as described in
RTSP gstreamer and vpudec
himanshugusain
Igor
What do you mean by measure delay without wi-fi
You want me to store media file locally in tool & play from there
& compare that with a good known device.
Himanshu
