iMX.7D JTAG_MOD default pulling
Question asked by Thomas Kofoed Hansen on Jun 23, 2017
Latest reply on Jun 25, 2017 by Yuri Muhin
Branched from an earlier discussion
Hello Yuri,
removing my pull-up resistor on JTAG_MOD pin solved the problem, which means that the processor sees the unconnected pin as low. Measuring the pin voltage also shows a low pin signal. All this suggests to me that the datasheet table 4 on page 19 is wrong, and that at least the JTAG_MOD pin (haven't tested the other JTAG pins) has an internal on-chip pull-down resistor and NOT pull-up as stated in the datasheet.
Can you confirm this?
